2nd Gen Non-Engine/Transmission Dana 80 rear brake questions
When I first bought my '96 back in '99, one of the first things I discovered was the rear brakes were worthless. After taking the drums off to see what the problem was, I discovered that my driver's side had the shoes on backwards to what I've always known to be the correct position: short shoe in front. The passenger side did have the short shoe in front. So I switched the driver's side to match. The rear brakes were still bad and always have been, but after years of being on TDR I know it has more to do with the tiny wheel cylinders than the shoe position.
The other inexplicable thing I noticed is that Dodge took the most round-about route for the driver's side parking brake cable and made it loop clear around and enter the backing plate in a sharp U-turn from the rear :confused: The passenger side enters the backing plate from the front like a normal vehicle and without any sharp loop.
The backing plates appear symmetrical with a place for the p-brake cable hole to be drilled for either left or right side of the truck; and either front or rear entry. I actually ordered new cables some time ago and thought I had what I needed. It turns out both new rear cables (left and right) are too short, or at least the housings are, even though I ordered them for an extended cab 2500. The drivers side cable I received would be a perfect fit if mine entered through the front of the backing plate like a normal vehicle and like the passenger side does.
Combined with all the various cable lengths available for a '96, this leads me to wonder if my truck is some kind of oddball? I already found out that there were two entirely different hardline configurations from the abs & prop valve to the frame in '96, so Dodge clearly toyed with changes that model year.
Does anyone else have a 96-ish truck with a D-80 rear that has both p-brake cables entering the backing plates from the front side?
I've owned mine since it was brand new and never noticed that the park brake cable enters the backing plate from the rear on the left side. The right side also has a bit of a loop since it is attached above the axle housing, then goes forward and back into the plate. I don't recall which shoes went where when I replaced them. I've only had to do it once and that was around 800k.
800K? Wow! I guess that says it all about how much work the factory rear drum brakes actually do! I'm running into mid-model-year part & design changes and discrepancies everywhere I turn when it comes to this '96 brake system. It's almost like owning a ford... :rolleyes:
Don't mistake that for an indicator of how much work the rear brakes do. I've only replaced the front pads twice. Most of my miles are highway and I have an exhaust brake. In addition, since the trailers I tow are not usually mine I find that use of the electric brake controller aids in seating their new brake shoes:-laf
Similar threads
