DEE 6 sp manual transmission
Pre-Turbo Pyro sensor?
check this out
Would like to hear from those who are shifting 6 spd w/o clutch, of any problems when doing so, suggestions for doing same. Also 2 tags on Xmsn say use of any other lubricant other than MOPAR P/N 4874464 voids the warranty. I have been told that Valvelene makes a manual synchromesh Xmsn oil called TRACLOC which is a blend of synthetic and mineral oils, which I am considering using after warranty. Would apperciate any input tnks.
This was shifted around recently and it seemed like most of the guys recommend using the clutch when shifting. I always use mine. Sometimes I double clutch while down-shifting just for fun. One of the guys said "it was put there for a purpose,use it. "
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
I don't think the syncronizers like the no clutch shifting as much as I would like to use it. It's a different transmission than the big Eatons and others found in the big trucks. I like no clutch shifting but have avoided it with this tranmission because of the syncronizers.
2001 HO 6 spd 2500, 4. 10 LSD, Towing Package, Electric Brakes, SPA EGT/Boost Gauges, Fog Lights, Real Backup Lights, Molded Running Boards
Sorry about the no clutch shift question, haven't been online since last fall, was busy buying/tricking out my new truck. Am still interested in any comments about using synthetic/synthetic-blend in 5600 Xmsn. tnks
2001 Patriot Blue DRW lmslip ETH DEE. Xmsn/Dif temp, Boost/EGT, Xmsn Filter, MagHytec diff w/synthetic. 9. 5', 91 Sunline camper (Home). GVW 10800. 5800 miles mpg @ 60 mph 15 (& climbing) around town mpg 13-14. Gauge readings @60 mph I 10 Fla, 70 degrees outside temp. Boost-8 , EGT 750, Xmsn-175, Diff-145. (Diff runs 25-40 degrees cooler than Xmsn depending on outside air temp.
I don't know that anyone has done a test on synthetics in the 5600. Supposedly, the additives in the recommended Texaco lube are required for the syncronizers to work properly. Also, the blend of this lube is such that supposedly it's the only lube that meets these requirements. Until a manufacturer successfully demonstrates their substitute lube will work I wouldn't change over to it. As much as I would like to change to synthetics, for now I believe we are stuck with the Texaco.
Well, 10,000/15,000 miles on Amsoil in all the Gearboxes except power steering and engine, Shifts Better every day. Break in was interesting when synthetic was first installed as it was very hard to get into gear. (that startled me!) This corrected itself within 200 miles. I suspect this was interaction with the old lube in the syncronizers. The difference from petro to syn was noticable.
I have run synthetic lubes in everything I own since the early 80's and have never regretted doing so!
Rich
2001. 5 2500 ETH/DEE 4x4,Patriot Blue over Silver,Camper pkg, Trailerpkg,3. 54LSD, Agate Leather,Stainless Smitty Bars,Tow hooks,Amsoil... ... ... :) Except snowplow!
Ak, welcome aboard. If you have access to TDR issue 31, there is specific information about using the clutch when shifting the 4500, and I believe that this applies to the 5600 too. Basically it statedt that the 4500 is built like an oversized car transmission and that there is a special coating on the syncro's that is not tolerant to clutchless shifting. It stated that the clutch must be used for shifting. The 5600 is not built like a large over the road transmission, which is designed to be shifted with double clutching or gear matching.
I've run the Amsoil series 3000 5w30 eng. oil in my 6spd. for 80K mi. now with no problems, will probably change it at 100K.
Larry
Y2K 3500 QC,SLT,4X2,White, 6spd,3. 54 lsd,Banks Stinger +,Pacbrake,Pilar mt. EGT & Boost,Amsoil air filter,all amsoil lube w/BMK-15 filter system,MagTec rear cover,putco boss rbs. w/ rear ext. &flaps,20K reese,100 gal. aux. fuel,fold up T cover,5K airlift bags w/comp. ,ranger 2950 cb pushing palomar 225 amp,phantom radar det.
I always use the left pedal. I know this old timer who use to be a heavy equipment mechanic and then he use to work at a truck driving school giving exams and training people who wanted their CDLs. He said that if the guy taking the exam didn't use the clutch he wouldn't pass him. It was put there for some reason.
2001. 5 2500 DARK GARNET QC LB 4X4 6SPD HO 3. 54 EVERYTHING BUT THE COWHIDE
I rarely use the clutch in the big truck, but always use it in the dodge. The biggest reason is syncronized vs. non-sycronized. Syncros don't like clutchless shifting, it's hard on them. Also the closer ratio spacing in the 13sp makes clutchless shifting easier. But the main reason is the syncro issue.
'01 2500 QC LB 2WD 6sp HO SLT+ leather 3. 54 ltd slp BLACK trailer tow and the all important cab lights. (for hauling motorcycles)
95 Freightliner FLD132 70" Condo 470 Detroit 13spd 3. 36 (to pay for motorcycles)
89 H-D FXRS, 99 Triumph 955i, 86 Suzuki GSXR750 ltd, 00 Aprillia SL1000
98 Yamaha YZF-R1(race), 95 Kawasaki ZX7(race)
94 27' Prowler TT (for some comfort at the racetrack)
