Alan Reagan
Andy-dirt, nothing special had to be done after the install. I cleared the codes, cranked it up and went for a run. It reset the code for low pressure at the nozzle. However, the pump is self priming and the error cleared after a couple more starts and the ‘permanent’ error was gone the next day. So once installed, the system takes over from there.
if you do this yourself, you will need the def tank retainer ring tool. About $24 on Amazon. It is also used for fuel pump removal on all Dodges, Rams, Jeep’s, etc. also, check the lines good after the install. The outpu at the pump is hard to get seated and will blow off under pressure if the lock is not seated properly.
