PK - if you read back up thru the thread, I mentioned a couple of times that I've tried virtually EVERY reasonable brake adjustment - from completely off, to a pretty decent drag - makes NO difference!
RT - thanks for the input - funny thing is, By brother-in-law had EXACTLY the same make/model trailer, just a couple of years older, and NEVER had any brake problems I was aware of...
Go figure!
I'll try the higher capacity backing plate assembly first - as long as it doesn't require a complete brake drum and wheel replacement - it that doesn't work, will have to seriously consider a total axle change...
All your comments on spindle nuts, springs, etc. , are acknowledged - and agreed with - I've noticed the same thing...
Go figure!
