Diagnostic code P0602
Fuel Power Additive
Oil analysis kit????? worth it
Just had a new ECM installed in my truck, immediately got P0602 code. Took it back to the dealer and was told it wasn't the ECM but the PCM so I had to pay for reprogramming. Reprogramed, got home had the P0602 code again. My research shows only a ECM in diesel trucks, PCM in gas powerd trucks. Do I have a PCM and a ECM or just an ECM?
Thanks.
2003 3500 DRW, 6 Speed Navstar, 184,000 miles.
Your 03 has both, the PCM is on the passenger side firewall. The 602 is a nuisance code, usually does not hurt anything, I know Smarty can stop it from re-occurring.
Is there a PCM on a 6 speed? Thought they were only needed to control the transmission on the CR's?
I guess I did not notice his sig, with the 6sp... so to be honest, I do not know for sure if the standard trans has a PCM or not, but I would guess not.
Now, I am fairly certain that you Cerb, do know, and by asking the question you are just busting my chops:-laf:-laf. Really good to have you around to keep me on my toes, Thanks, Jess
Not busting your chops, I am not sure if the manuals had\have a PCM. :-laf The 03 models were a transition year so its iffy what they actually have at times. I though most of the funtions aside from trans control had moved to the ECU by then but always find out new things that are not supposed to be ther. :)
Thanks for all the help, I did spend some time today looking for the PCM but couldn't find one. This is one of the early 2003's I got it in 2002. Again thank you for your help.
2003 3500 DRW SLT, 6 speed Navstar
Who ever installed your ECM did an incomplete job. There are a number of steps involved that could be skipped and still run ok
