Differential as lift point?
Need Help
Drove new duramax w/ allison
Hello all,
I finally got myself a floor jack, and have a question for the group.
Is it safe to position the jack under the rear differential? The manual does not show it as being a recommended lift point, but it would sure be easy to use the differential as a lift point and then put jack-stands under the axle tubes.
Thanks for any info.
Tim
Tim,I do it all the time. Just keep it off the edge of the cover so it doesn't get loosened up and leak.
97 3/4Ton, 2WD, 5SP, #11 Plate, 14 Housing, AF942M Air filter, Gutted Cat, 4"From Turbo, Shortened Frame, Custom Bed, HEY FORDBOY POWERSTROKE THIS!
Tim. I have always lifted the rear of my 3500 with a floor jack under the center section of the axle and then put jack stands under the axle. I have never had any trouble caused by doing this.
Me three.
98. 5 3500 QC 4x4, Driftwood/Mist Grey, 5 spd, 3. 54, 19. 5 Alcoa's, 245/70-19. 5 Michelin's, Ranchhand front bumper, Ranchhand rear bumper, Ranchhand toolbox, "Scotty Air", TST PowerMax2, Autometer Gauges, Centerforce clutch, Upgraded fuel lines (JRE and Aeroquip), MagHytec Diff Cover, PacBrake
i don't know if you've looked closely, but if you 1) have a rear swaybar and 2) want to use jackstands, there really isn't any other option (at least not with the size of my jack and jackstands).
-dm
2001 SLT dominantly valved ETH quadcab 4x4 dually
icq61308432
