2002 3500 Dana 80 auto and a factory sway bar
I have a question on the Mag-Hytec cover. I have one to put on next weekend. From the info sheets that come with it, depending on where and how the factpry markings were applied, there could be a sealing problem. How many have had a sealing problem? Is it common?, or just a possibility?
Second question. I have the factory anti sway bar. I got the spacer kit for the sway bar. as far as I can tell from the diagrams, the mounting on the drivers side is already as far to the rear as possible. the furtherest mounting bolt to the back is right under the shock mount. The passenger side can move back and there is a already existing hole for one of the bolts further to the rear of the bracket. It appears that I only need to drill one new hole for the passenger side.
Does that check with anyone else?
Thanks,
Bob Weis
