My dipstick tube was cracked and leaking oil so I went to change it. I thought I'd just pull it out as it just pushes into the block and seals with an oring. The tube broke off right where it goes into the block. I removed the starter to get a better look, can't see much. I've tried threading things into it and pulling it out, I've tried easy outs, nothing seems to work. It looks like I need to remove oil pan and push it out from underneath. From what I can find out you lift the front of the engine with a crane, remove mounting bolts, and once engine almost touches firewall you can remove pan. I now have a 1/4 tap broke off in dipstick and feel pretty dumb. I guess I should have checked here. Any advice?
