Cummins Cowboy said:
correct me if I am wrong arn't the hubs being talked about the kind that require getting out of the truck and turning the selector on each wheel??? if so I can't believe people get so excited about them, who wants to get out of the truck to turn the darn things on?? I don't, where I live we get ice and snow, usually the residential areas are the worst and the main roads are fine, its sure nice to just yank the 4x4 shifter while leaving the neighborhood and shift out on the main roads, or getting caught in a snow squall, and shifting into 4x4 while moving. I personally think the manual hubs are a joke, All my buddies that have mid 90's fords had to replace those manual hubs shortly after hitting 100k, once I had a buddy that his where bad without us knowing it, we found out the hardway on a road in the middle of no where stuck in the snow. that has been my experinece with manual hubs, They suck, and are inferior to the modern setup on our rams, not only for convience sake but having to replace the darn things after 100k miles
First, IMO they are by far superior to the non-replaceable unit bearings we currently are offered... I want something serviceable, not throw away.
Would you rather spend $250 on a unit bearing or $50 on replaceable bearings? Would you like to replace components (tcase chain, axle joints, diff bearings) you hardly use because they wear out since they are always spinning??
As for winter driving... if I know it will be bad (or potentially be bad), I simply lock them in and forget about them. No fuss, no problems... when locked in they are the same as your "great" unit bearing hubs.
I also live where they get snow for about 4-5 months of the year... but how often do you actually need 4wd? I can count on 1 hand how many times I actually used 4wd last winter. And no, I wasn't pushing it to see just how far I could go, I had the hubs locked in, but if I don't need 4wd, why engage it??
I personally have never seen a quality locking hub have any issues... I ran them for many years. Ford hubs are junk to begin with... I won't even go there...
The few people who feel like you about locking hubs are the reason the rest of us are stuck with the lazy-man's unitbearing hub. It is this modern "throw away" or "disposable" society we live in that has driven the cost of stuff up...
And it is a personal choice, I prefer to be able to choose when I need the front axle engaged, so I can get better mileage, longer life from those components... if you choose to replace unit bearings about every 100k and pay more for fuel because you like to have the option to pull 4wd anytime (including when the roads are completely bare and dry), so be it... wish I had your money to burn.
steved
