Just wanted to give the group a quick heads up on replacing the disk brake pads. I had 86500 miles on the orginal pads and I though I had better change them. In measure the remaining pad thickness, they ranged from 11/32 to 13/32s, may have pulled them too soon, but as a full time RVer, don't often have a nice driveway that is smooth and convenient. So I took this opportunity to do them while at my son's house instead of some park on gravel.
The Service Manual does a fairly good job of explaining the process, but it does not mension how to "Compress Calipher Pistons" with the caliper attached. Also the passenger side caliphar is upside down from the driver's side caliper. That means Dodge makes one caliper and uses it on both sides. My 95 Dodge caliphers were mirror opposites (if I remember correctly). The point to all of this is when removing the caliper you need to pull out the top and lift up from the bottom of the caliper. So the top and bottom of the calipers are reversed between the driver and passenger side. Also be aware the "Anti Rattling Clip" are not interchangeable from top and bottom, so beware.
But all and all replacing the pads was not that diffecult, so all of the DIY's (Do It Yourselfers) out there, have no fear, save yourselves some money.
If any of you have a good way of "Compressing Caliper Pistons", would be interested in hearing your comments.
Travel Safely
Travel Safely
