Darkbloodmon
I'm still in the throes of my clutch job on my 03 and then some with resealing everything and waiting on additional parts and bits. I noticed this as I was trying to install a 2nd Gen swap turbo drain line kit which won't clear on a 3rd gen stock turbo application....
I finally found the the source of a long term oil leak I had been monitoring. I replaced my turbo feed and drain lines/ hoses shortly after I got the truck. The drain tube kit I used was a Doorman 904-346, I got it off rock auto, but a quick search will show other diesel truck online retail vendors selling this Doorman kit, It came with a new bung including the O-ring, the hard line drain tube, gasket and the SILICONE hose fitting.
Silicone is not compatible with oil, unless it's chemically treated for it which this cheap Dorman set was not. Silicone hoses will sweat oil flowing through them. This sweating in my case was not enough to leave puddles, but small drips on the driveway, I've had this drain tube kit on for at least 10K miles before an oil analysis.
This further confirmed the results of my later oil analysis that had moderate to abnormal levels of silicone. At that time I had not re-sealed anything using silicone and nothing on the oiling system had been sealed with silicone products by the previous owners and as I'm looking at the nether side of my engine now doing a rear main seal and oil pan gasket; everything has a factory gasket.
Additionally in this kit; the Dorman bung appears to be a solid piece, but the fit with the O-ring feels sloppy in that you can swivel it around but feel the O-ring grab the sides. It's not comforting that it can be moved around so much with only the single O-ring holding it back. So I'll be looking for an OEM one or a higher quality aftermarket one that seals more securely.
Hope this helps someone.
