Engine/Transmission (1998.5 - 2002) Drive shaft bolt size
2nd Gen Non-Engine/Transmission Changed gear box
2nd Gen Non-Engine/Transmission Hub bearing bolts loose!!
Does anyone know what size the bolt is that hold the drive shaft straps to the yoke is on a dana 70U on a 2001 dodge ram 2500 2wd???
If like my 1997, the bolt head is 5/16" on the rear and 3/8" on the front. Be sure to use a six-point box end wrench as they are loctited at the factory.
