Moolie, slow down dude. Do you have full gauges to see what is going on with the 2 turbos? I mean, one total boost gauge that reads past 60, like a 0-100psi. This should be off the intake somewhere. Another to read the charge out of the Big turbo, to see how hard your driving it. A third in the exhaust manifold to see what drive pressures are doing.
With these 3 gauges, you can tune the twins. Maybe the wastegate is opening too soon, and the big turbo is being overspooled. A balance between them is key. Not sure what the turbos are, either.
Lastly, what kind of injectors are the ones you have from ATS?
Piers runs stock injectors with the TST, we all know big injectors don't play well with the TST, not sure about your box though, never used it.
I have a truck in Vegas that is pushing 590 with TST/EZ,100HP injectors, Twins(35/3TB) and Propane. We are going to pull the injectors and go with Flux injectors, when the guy is ready to move that direction. We spent a good amount of time tuning to get it just right, and it has run a 12. 8 at Vegas.
Water/Meth is also one of the next options we're going to add, real soon.
How much smoke do you get when running it hard, and the EGT's are pegged? Iif it smokes like crazy, I'd be looking back at the injector/box combo.
On this guys truck, he ran the best times and most HP with the TST on a lower setting, not a higher one, as most would expect. The injectors are hurting it there.
Food for thought.
