Your problem has nothing to do with the gear ratio, it is a balance problem. These problems can arrise from poor tire quality, bent rims, bent rear end housing, or missing /borken rotating parts.
Tire quality has nothing to do with tire price. Sometimes you just get a bad tire, one that slipped thru the quality control department. And yes there are a bunch of tires that do not make the cut, so when somebody tells you of a deal just too good to be true, well remember all those blem tires?
I have had several tires myself that were out of spec. The latest ones were from TRXUS. I ordered 6 and out of the 6, 4 were in the 2-3 oz range, which is great for large mud tires. One was 5oz's out and I had one that was 24oz'a out. Ok, first let me clairify some things. When I refer to a tire being 2-3oz's out, that means that when that tire was mounted and put on the balance machine, It needed 2-3 oz's on lead weight to bring it in balance, just so we are all on the same page. Now the 5 oz'er was pushing the envelope some, but exceptable. The 24 oz, think about it? it needed a 1lb and a half to balance out! this one was clearly a blem that got thru the system. I just called up 4 Wheel Parts, were I bought the set from, and they arranged for ups to pick it up, and then sent a new one. This was ok for me, I do not use my truck, but it would have been a pain for someone who needed there truck on a daily bases. The whole thing took about 2 1/2 weeks. Any how this was just an example of how tires are some times out.
The rims can also be a source of im-balance, wheather it be through and accident (hit a curb, or somebody), or just bad from the factory (yes I have had one of those to). Also alot of people get wheels from the junk yard, for that extra set of tires, only problem is most of those wheels are there because of a wreck.
Then it could be a balance problem form something as simple as a missing lugnut, hey I know what your thinking.
Anyhow point being there are many sources for a balance problem. I reckon if everything checks out, then you might want to look into the Centrimatics. They do seem to work and nice thing is you can take them with you if another truck is in your future. I didn't have a balance problem when I got my, I was just noisy and thought I give them a wirl. The on highway ride is were they shine, they seem to give a very smooth ride. Much less shaking at the wheel, and it is quieter also (till I put on the 4") Good luck.
