Engine/Transmission (1998.5 - 2002) ECM needed A.S.A.P!
Cummins724
My brothers 98. 5 CTD 5 speed truck broke down on Saturday while driving to my home. He is getting a code P0230... Transfer pump [lift pump] curcuit out of range. The truck has a Holley blue pump using the LP harness as a triggered relay. I tried disconnecting the harness altogether & no changes. I need a ECM for this truck soon & hoping to find one local if possible for a quick install.
I installed the ecm out of my 99 into my brothers truck today & that was the problem... . it is running great. My truck is sitting in the driveway with no brain.
Did you try verifying that it was actually an ECM failure, and not just a bad connector or connection? Sometimes a bit of corrosion develops in the connector, and operation is restored when it is unplugged and then re-connected - I'd sure want to verify it actually IS an ECM failure, not simply a bad connection... ;)
I tested voltage coming from the LP harness at the ecm. My brother hit the go pedal & voltage dropped to 5v at any throttle position. I unplugged the ecm connector & cleaned it, lubed it, reinstalled it & nothing changed. I checked all grounds & checked out well. When the voltage would drop to 5v... the "wait to start" light would flash. I disabled the turbo timer taking everything back to stock making sure that this wasn't just a ignition switch problem cutting out power & nothing changed. I did this because my brother said he went to turn his truck off one day at Walmart & it didn't shut off, but he turned the key forward & it shut off. He also had code po253 show up any time temps would get below 40*f. All leads me to ecm.
I was gonna have it repaired if I could find a electronics shop that knows how, any ideas?
You might check with Bob Wagner... . I know Marco has repaired a few ECM problems. The ECM has to go on vacation to Italy, but it will come back happy.
HI,
I have a brand new ecm (Mopar performance parts). This ecm was sent to Marco and has the Catcher program. 2001 Automatic Federal emissions. My info e-mail -- email address removed -- or Home # 425-355-3915. Thanks, Sam.
Ecm
anybody have an ecm out of an automatic truck for my 01?
The ECM I posted is programed for an '01 Automatic with federal emissions. If you need it my e-mail is -- email address removed -- or call me at 425-355-3915. Thanks, Sam.
