Edge EZ Helps Mileage!!!
tachometer markings
daytime running lights
I have nearly 100K on a 2000 that hit the road in May of 2000 and I have checked the mileage on most tanks. I have ranged from 9. 5 MPG to 18. 75 MPG pencil figured, no trip computer, and adjusted for tire changes. I installed the Edge EZ and settled on the middle setting and have checked the mileage on my first trip. It had 70% Hwy and 30% city. I got 20. 54 MPG not trying very hard. It would have been a 17. 5 to 18 MPG tank before the EZ was installed. I love the power and will be very happy if the mileage goes up 1 to 2 MPG across the board.
Me too.......
I gained 2 MPG steady when I put mine in. Lost ½ when I went to the DD2's. Gained it back when I installed the DTT transmission stuff.
I'm playing with setting #1 right now to see if there's any gain that way. I rigged a switch to get me to #3 if I have a need for the extra power.
Garrett
I have seen about 2 mpg increase with my ez. In town and freeway both up. And my cruise doesnt down shift on the hills that it used to. I love it.
I also noticed that my throttle position is much less for the same speed/acceleration. My E-brake is set to come on after a couple of seconds of delay at no throttle. It used to only come on while decinding the biggest hills while the cruise is on. Now with the "lighter" throttle required it comes on and keeps the speed closer to the set speed. It also will maintain the set speed up hills with a lot fewer WOT runs. This has to help mileage.
