Edge EZ settings (not like instructions)
Adjustment procedure for linkage rod
Question about "Trailer Tow" option...
I just installed my Edge EZ and took it for a test drive. I can feel the new power, but not as much as I expected. I also installed the boost elbow and can get about 24 LBS empty. I got home and wanted to check that the setting was in the most agresive position. I pulled the cover to look at the 6 pins. ( 3 sets of 2) and found that the two left sets have the small plastic jumpers installed. The instructions only show one jumper intalled at a time and indicated it would be on the right hand pin position(most aggressive). I got the box from smokindeisel and they are closed for the week-end. I chose their box that has one timing only position and two timing plus fueling positions. I only got the regular EZ instrucions with the kit that indicates that it has 3 timing plus fueling positions and the jumper should be on the right hand pins when new. Any help would be appreciated!!!!
Move it to the right for maximum fueling!
The TTPMs have a timing only setting far to the left. Sounds like that is what you are on.
-Chris
I don't know about the EZ but I just installed the adjustable Comp from the same guys and they were great. I pulled my boat and it was :eek: :eek: :eek: great.
Jon
I would move it to the right, however there are two jumpers not one like the instructions. Should I take one off? Should I move both to the right and leave the left position blank? Please help!!!!
