Electronic Brake Controller
slide out room extensions
Addind a 9.5 ft camper on my 97 3500 2wd trk
I need to purchase a new brake controller and am ignorant of what is available out there. It has been several years since I purchased one. Any suggestions?
Have owned a couple Techonsha(sp. ) units. Good adjustability, self-leveling and some have a pre-programmed setting for when your empty or loaded... just click #1 or #2 positions!
97 2500 CC 4x4 3. 54 5spd, Green, #12 plate slid all the way forward, 4inch open exhaust, 235/85 Michelins, RS 9000's, PrimeLoc, Red Tops, TDR cloisonae grill badge!
Suggest you search through the Products area.
Draw-Tite, Hayes, Napa, Jordan Research, Tekonsha and Reese are a few names.
Warning: If you install it yourself watch the colors on the control compared to the truck wiring because they don't match up.
[This message has been edited by BV (edited 12-28-2000). ]
I have the Tekonsha Sentinel - no problems and plugs right into the socket under the steering column #ad
:. This was a good thing as I am electrically challenged #ad
01' 3500 Bright White,QC LWB, Auto, 4:10, Line-X Bedliner, Member San Jose RamRunners
2000 Dutchman Travel Trailer
1996 Harley-Davidson FLHR
Tekonsha makes 4 or 5 different models,depending on your wants or needs. All
models have a 5year warranty. I use a Tekonsha
Sentinel & am extemely satisfied with it. Hope
this helps. Rick
I use the Tekonsha Sentinel also,works great,but what I find more important is a good exhaust brake.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
Draw-Tite Activator II is what I've used and the one a few of the trailer shops in my neck of the woods claimed to be the best. I have been very satisfied, a couple of different adjustments available to dial it in for diff trailers and loads.
2001 2500 tow, camper, SWB, ETH, Bright white.
