Emergency Flashers won't work?
Loooooooowwww Idle
DD3s
My 2000's emergency flashers won't work. I checked all fuses and flasher elements under the hood and left side of dash with door open. Turn signals, running lights and brake lights work fine. I have never seen this. Usually if your turn signals both work and the flasher element works then the emergency flashers do too. Can anyone give me assistance?
Just a thought ,,,,,,,,,,,
Have you checked to see if you have a bad connection or bad button on the steering column housing? It shouldn't be too hard to take the housing off to get a good look at the button.
Just an idea.
Same Problem
I am having the same problem... ... chased down fuses, checked connections, everything seems to be fine. Let me know if you have any luck, and I will do the same.
Chris
