Engine/Transmission (1998.5 - 2002) engine died
Engine/Transmission (1994 - 1998) fuel pump mod for 96 td
Engine/Transmission (1994 - 1998) Front rotor only
This morning I started my truck and was letting it run to defrost my windows, and all was well until about 3 or so minutes into it, I heard a muffled clunk or 2, the engine revved about 1000 -2000 rpm and then it just died. I tried re-cranking to no avail. Temp around 28 or so, ice storm last night with about 1 inch of ice on everything.
Anyway later this morning after letting it sit a couple of hours and really the temp is only about 3 - 5 degrees warmer, (slightly above freezing) I got in and cranked and she fired right up. (I still haven't run it long enough to warm up but my fear about something expensive to fix is fading a bit) anyway my question is this: could this be a fuel gel problem?
Another piece to this is this truck was fueled on a tank of gas in early fall, (I am not running it because I am trying to sell it) and I am wondering if the grade would be summer and that would be the difference OR even the age of the fuel.
I sure would feel better knowing it was a gel problem I guess is what I am getting at.
Sounds like it was on the verge of gelling or you might have had a little water sucked into the fuel line that was beginning to crystalize and temporarily blocked the fuel until it warmed up a little.
I hope you mean #2 diesel instead of gas. :eek:
Assuming you do, the diesel may well be full of biological growth if it's been in the tank since early fall. Diesel will degrade with age - algae love to grow in it! Biocide additives are available that will deter this growth. If you haven't put any biocide in the tank, the fuel filter may well be plugged.
Rusty
