The old CTD has started missing or surging, but not all the time. The only code it threw is P1682 which is low battery voltage or alt output. That problem seemed to clear itself. Need some help on where to start looking. Fuel press is 14lbs at idle and only changes as I mash the pedal down. When it starts missing, the tach increases in rpm. I seem to hear the VP44 rattling like noisey valves at times and I run a cetane booster in it. I also have an EDGE EZ box that really works good. Any ideas, Moe
