Cavitating and Bypass Switch
Hi Merv, the bypass switch made the pump run, even during the times when before, the pump would have been erratic, but it also back-fed 12v to the ecm which caused some surging during normal driving. So the bypass switch had to be used only when we thought we may be running it hard. It is not a blanket cure. Maybe a diode in the line would prevent the backfeeding to the ecm?
Hi Jon, as for cavitation, my understanding is that cavitation is created on the suction side of a high pressure pump, or at the inlet side of a pump. The air we are experiencing is in the injector lines down line of the injection pump and on the high pressure side of the pump. So I don't think we have cavitation in the lines, there could be cavitation at the VP pump inlet if it wasn't getting enough lift pump pressure or volume.
In aircraft applications where a high pressure pump is needed for hydraulic pressure, the supply side or the resevoir is pressurized to provide enough head pressure so that there was no cavitation of the high pressure pump. Usually the resevoir is pressurized with air pressure which also reduces foaming of the returning high pressure oil. Sort of like our lift pumps provide steady [we hope] head pressure to the VP44.
We installed the FASS, and it sure runs better, but we still aren't satisfied that it won't stall if we lift abruptly. Snowy roads are keeping us from more testing.
Take care, Greg L. TheNoiseNazi
Great Lakes Diesel Works
DTT transmissions
Performance Shop
