Espar D5 coolant heater install and impressions
Chrysler Corp.
Airbags...2wd versus 4wd...spacers?
I recently installed the Espar D5 unit and thought I'd share some thoughts about the install and operation.
Install: The install for this product is not particularly difficult but it is time consuming. I dropped the tank for the pickup tube but did not use the one supplied by Espar in the kit, rather I made my own with a brass bulkhead fitting and a piece of 1/2 ID air line. I did this because I wanted to utilize a pickup that would work for me if I decided to use the walbro pump sometime in the future. I also used another bulkhead fitting and some 3/4 hose and put a new vent in the top part of the tank for easy filling. The vent kit is a no-brainer if you are dropping the tank.
Dropping the tank was not difficult but I did wrestle with the electrical connection on top of the tank. Once you slide the red safety to the side of the connector you need to press down on the tab to get the connector off. It seemed I was lifting on connector at the same time I was pushing on the tab and it did not want to come off. Once I put some down pressure on the connector while pushing the tab it slid right off. The fuel connectors are easy to get off and cannot be mixed up. Having precious little fuel in the tank makes the tank dropping part quite easy. The kit I bought had the dosing pump separate from the espar unit and apparently this is a more trouble free design. I mounted the dosing pump on the inside of the frame rail and used an inline filter ahead of it.
I had to fabricate an aluminum bracket to mount the unit under the airbox as I really did not want to frame mount it, but a frame mount would work if you fabricated a shield to protect the unit from rocks etc. It is a tight location but it will fit. I used the tab sticking out of the frame rad support for the main attachment point for the fabbed bracket. I routed the hoses up and installed the Espar outlet into the heater core inlet, and the Espar inlet pulls coolant from the top of the engine. Simple install and works very well.
The 7 day timer installed under the center console cutout in the center of the dash. You have to cut the harness to length and install the wire ends to fit the timer. I ran one extra wire from where the yellow installed to use as a relay trigger for the cab fan and also one extra lead off pin #7 to utilize a ground pulse lead off my remote starter to start the Espar.
There were no directions in my kit in regards to hooking up the cab fan so I got the multimeter out and determined dodge (06) runs the cab blower fan ground through a resisitor to change speeds. I used two relays, one to power the blower fan from the Espar power on wire (yellow off the back of the timer), and the other relay powers the cab blower from "key on" power.
Operation: This unit works fantastic. It heats the coolant from -10* F to 150* F in about 90 minutes. The block is very warm to the touch all over and with the cab fan set on defrost and low, the windows will clear heavy frost in about an hour and hte cb is toasty warm. It is somewhat noisy while running on high output and people will look at your vehicle with a puzzled look on their face while walking past in a parking lot etc. This unit uses about 10% of the fuel it would use if you idled the truck and gets the temp much higher than a block heater can.
After using it this past week I would highly recommend it to those in cold climates. It is expensive, about 2K - 2. 5K Cdn dollars installed depending where you go. I paid $1330 Cdn for the kit. Add another 50 dollars for the bulkhead fittings, hose and relays.
I've been running it for 90-120 minute time periods with no battery power issues whatsoever. One bonus is the heater does such a good job warming the engine the grid heaters do not come on when you turn on the ignition. I suppose its a trade off, cab fan running on low for a couple hours vs grid heater draw.
I had the espar kit installed on my 2007 at the dealer before I picked it up, and I agree, the unit performs fantastically. And I also know the feeling of people coming up to me while the unit is operating wondering what the heck I have running... lol It sounds like a little jet engine running.
I have the mini-clock programmer which allows you to preset 3 times to turn on per day, but wont cycle every day (have to set it to warm up every evening when I get home. ) Which is enough for me. I was thinking about the 7 day programmer, but its a bit large and I really dont need to think about accidentally leaving the darn thing on over a weekend and having it waste battery power.
One tip I do have for using it is that you should set your cabin heat to max, floor outlets only and recirculation on before you shut down for the night. Recirc dramatically increases the amount of heat put into the cabin as well as retained by the engine block. On a 15 degree night, with the recirc on, I came to a toasty warm truck with a 150 degree coolant temp. The same temp night with the heat on the same level but with fresh air input, the cabin was significantly cooler and the engine was not even 140 degrees after 60 mins of runtime.
BTW. On my 07, the espar mounts under the cabin next to the transfer case up next to the chassis rail on its own bracket as well as having its own solid (non flexy) exhaust pipe which directs the exhaust down.
-Dan
I have a D4 mounted in a box under the passenger's floor. The previous one was not in a protective box and the road spray from the front wheel migrated into it's controller.
Have had espars in several trucks and am very happy with them. Perhaps the next one will be a D5
I always wanted one when I raced sprint cars. Only the richest teams had them back then, us "po boys" would just use blankets and a torpedo heater :-laf
abrankod, I like where yours is mounted on your '07. Looks like a piece of cake to work on it.
Bought mine during the promotion after it was featured on two-guys garage about 8 years ago. About $899.
It's a nightmare to work on where it's mounted. On the special bracket just above the starter. Pulling the Espar seems like a 3 hour job. I can't get my hands on the hoses to R & R them to the heater. No room.
I got hit w/ Fault 41, 2 years ago. Needed a new waterpump.
Now it's throwing Fault 64. It won't light if it's cold out. Need to replace the flame sensor. Another day to R & R it.
Would I buy another one? I doubt it.
The units used at the track were stand alone, would that be a cheaper option? Just had to plumb in the quick disconnects.
Wiring the Espar to the Cabin Heater
Very informative description of the install and impressions of the Espar. I've just ordered one to install on an 06 2500. I think I follow the whole thing except the wiring to the cab fan. Can someone walk me through the two relay wiring to make the fan work. Thanks.
The instruction manual is available here(PDF)
The whole install is very straightforward. I doubt you'll have any trouble with any of the hookups aside from the sadness of drilling a hole in your baby's dash :O
-Dan
Santa Claus brought me one for my 06 for Christmas. The dealer said it was the last one in Chryslers inventory. They are carrying for the 7. 5's and newer but you can still order a kit from Espar. Wife paid 1200. 00 for the Mopar kit for my truck.
