Might I inject some math here?
I don't think it is simply top speed that wins 1/4s. It is a combination of top speed and how fast you can reach it that determines ETA. Looking at Eric's numbers, I would hav eto say that Eric is accelerating quicker than Doug or Nowel, even though his top speed is lower.
At 60MPH, it takes 15 seconds to traverse 1/4 mile. Suppose you were to reach 90 MPH at 320 feet and maintain that speed for the next 1000 feet; also assume 0-90 was linear, thus an exact average of 45MPH over 320 feet. The resulting 1/4 miles time should be 12. 42 seconds.
If you reached 90 MPH at 160 feet and held it, your ET would be 11. 21 sec.
If you reached 90 MPH at 60 feet and held it, youer ET would be 10. 45 sec.
Now, let's change your top end.
If you reach 110 MPH at 320 feet, your ET would be 10. 16 sec. 110 at 160 feet, your ET would be 9. 17 sec. 110 at 60 feet, your ET would be 8. 55 sec.
By now, it should be clear that the faster you reach your top end, the faster you will traverse the 1/4.
To reach your top end the quickest, you need *lots* of torque at the wheels, and tires that can connect that torque to the ground. Of course, simple thrust would work as well, but then you'd be out of the diesel class, eh?
An engine that makes 1000 HP at 12000 RPM should accelerate my truck
about as fast as my mostly stock 12V does. Well, maybe faster. After all, it *would* be staying in lower gears longer, thus taking advantage of the torque multiplication of those gears.
Have I adequately muddied the issues now?
Fest3er
