I too am wondering about an exhaust brake for my truck. Currently do not have a controller with my DTT and was looking into the Banks one. A friend of mine with a current mods and a 6 speed worked great. He has tows 35' toy box and it works great. I believe the Banks uses engine vacuum, not a seperate pump. I have hot street car with a high lift cam... anyway I have a SSBC vacuum pump and it runs evertime I use the brakes. Somewhat noisy outside the car. What are your thoughts
Thanks
I read you need to change the vacuum supply hoses every couple of years for a vacuum controlled brake when I was looking at the BD Power website and reading about their exhaust brake. At least I think it was the BD site, I looked at a few last night. I would probably want the air actuated design.
Also, the BD site talks about the need to upgrade the engine exhaust valve springs for certain 24 valve engines. Any thoughts on the need for stronger springs?
It sounds to me like BD is using carefully worded falsehoods to sell their product.
If memory serves me correctly, all 24 valve engines have had 60 psi valve springs. Some earlier 12 valve engines required installation of stronger valve springs to tolerate 60 psi back pressure created by an exhaust brake.
The variable orifice of the BD and PXRB does allow for more bottom end braking, but from about 2400-2500 (depending on EGT's at time of application) they are all the same.
The BD brake does not have a variable orfice that open or closes with the butterfly. It uses a solid round disc (butterfly).
This is why I chose the BD over the others. Less moving parts and less to wear over time.
160K and counting on original BD brake and air compressor without any problems.
Exhaust brake sounds good, but I do not want to spend the money, at least right now.
I am considering installing the maxbrake controller and NOT installing an exhaust brake AND towing a 5th wheel with a gross weight in range of 12K. Is this sound logic or should I rethink my plan? Any and all opinions and input appreciated. Thanks!
Just curious, what do you not like about using the ECM to tell the brake when the truck engine is at idle?
I haven't thought about using the ECM that much. I read a Pac Brake install pdf, I would be a little concerned about wiring in their harness to the ECM, concerned I might be too clumsy or fat finger something and cause damage. It seems pretty simple if you can get to the ECM.
Per their website they do. I think they made a change in the last few years becuase their original brake wasn't as strong as the others (backpressure wise).
BD Power - Product: Exhaust Brakes
I don't like how BD or Banks use the ECM for EB operation. It increases the cost to be stand alone, and Cummins/Dodge already have logic in the ECM for an EB.
Ummmmm, I think you better read it again
How it works: Using BD’s exclusive Variable butterfly Technology, providing peak retarding power throughout the engine’s rpm range unlike some models that rely on a hole/orifice within the butterfly to calibrate back-pressure only in the higher engine RPM .
