I remember getting mine in 2001 directly from Jacobs. I have no idea how competitive their pricing is or if it even is. I would check though to cover all bases.
I too am wondering about an exhaust brake for my truck. Currently do not have a controller with my DTT and was looking into the Banks one. A friend of mine with a current mods and a 6 speed worked great. He has tows 35' toy box and it works great. I believe the Banks uses engine vacuum, not a seperate pump. I have hot street car with a high lift cam... anyway I have a SSBC vacuum pump and it runs evertime I use the brakes. Somewhat noisy outside the car. What are your thoughts
Thanks
Greetings Mbutrch,
I had the Banks Exh Brake installed on our '4. 5 RAM 3500, SRW, 2 years ago for RV'g with our 14K# 5'er, (22K# GAVW). It was a lenghty install, many parts & pieces. Bottom line, Banks is most efficient in our opinion. They designed their exhaust valve to add NO additional restriction to the exhaust path during normal operation. Others add varying degrees of restriction. The controls are vacuum operated, including a pneumatic piston at the transmission to force near max. line pressure to the torque conv. to assure optimal lockup when braking.
Our 22K# rig maintained 58 mph downhill a 6-7% grade, towhaul mode, which felt very much in control without using service brakes. Due to being a '04. 5 truck, the exhaust brake ceases operation below 1100 RPM. I tested it also on a 4-5% grade in 2nd gear, which limited my speed to about 48-50 mph.
Braking effect is directly proportional to engine RPM. I don't measure exh press. My truck never warms up in Wisconsin Winters at low speed driving, expecially not in idle! Turning on the exh brake, closes it to enhance engine warmup, then opens at 140 deg. coolant temp. Very nice setup that Banks designed, and their customer support is top rate. We now have their Economind Diesel Tuner, so we go up a little faster and down a lot slower!
Sounds like you lost the vacuum pump. If you still have the OE belt I would bypass the pump.
Don't let the dealer replace it, unless warranty, becuase they charge over $800 for the pump that Cummins charges about $200 for.
Anyone have a good source for the Jake? Cummins is currenty asking far more bucks than the dealer does.
AH64ID,
I may have been mis-informed but, that is how I heard of the "Inline" brake. When I mentioned that I "may" want to upgrade the turbo, in the future, it was recommended to go to the Inline system. Now, I don't know who's right???
Your comment about the Inline system being slower to pressurize is what I thought would happen but, I've had at least two people mention that they couldn't tell any difference between an Inline & turbo mount system.
I'm not trying to "challenge" your comments, as I highly respect what you have to say. I always pay special attention to your posts as they are often very informative & appreciated. Thanks for posting your thoughts. More food for thought.
Once again, does anyone know if $1,200. 00 for an Inline System is a good price??? Sometimes, it's a major PITA when a main priority is "getting a good deal"!!!!! It's HELL to be CHEAP!!!!!
Thanks.
Joe F.
