Exhaust Brake
If you decide to remove the center seat...
BODY LIFT ANYONE??
Has anyone installed the TST exhaust brake ? I've been surfing around and came across the TST brake. I know most members that have the "e-brakes" are using either the Jacobs or B+D models. Any suggestions would be appreciated.
Being prep'ed !! 2001. 5 3500 ETH/DEE 4X4 quad cab SLT,trailer and camper prep,white. Currently own: 98 2500 slt quad cab 5. 9 gasser, auto trans. and lots of money in the tank !!!
The brake from TST is the Pac-Brake. All are good brakes. The only thing i have found to consider is if you plan to upgrade the turbo housing the E-Brake will not accept a non wastegated housing.
I had the US Gear brake on my now-sold truck. It was a wonderful piece of equipment! I spoke with the owner just yesterday, and it is still operating perfectly after 5 years. Compared to the other brands, its operation is more quiet so it can be used in town without nasty looks!
bpete
There is no problem using a PacBrake on a non-wastegated turbo housing.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
Thanks for the posts gentlemen. "It's all good".
