Exhaust Brakes
Cummins Quickserve
Emergancy brake adjustment
Hi Gang
Although I am new to the TDR, I have owned 2 Dodges with a Cummins since 1997. I am interested in installing an exhaust brake on my 99 3500 4X4 with an automatic, any suggestions? I have also heard about a mystery switch but cannot seem to find the defenition of what it is or does. I know it is related to the automatic, just not sure of what else. If anyone can help me I would greatly appreciate it. :D :):eek:
The E-bake on a auto trans voids any warrenty you may have. (trans warrenty) If not a concern the mystery switch is a override that locksup the torque converter. When useing a E-brake with the auto, the trans builds up to much heat. This is a way to limit that.
Hope this helps.
Mike
Originally posted by JCotte
Hi Gang
Thanks Mike
I appreciate the info? Does the Mystery switch replace a controller? Is it better to install a controller rather than a mystery switch? The truck has 80,000 so the only warranty left is on the engine, will that be effected?
Bob
Does the mystery switch replace a controller or are they one in the same? I was not sure if the mystery switch was a simple Home made controller or if it was a store bought controller. Any idea or recommendations on an E/B?
JCotte
Do me and yourself a favor and call Bill Kondolay toll free 1-866-504-4002
The "smart controller" is the only way to go.
Bill K. builds the coontroller and he will give you the best advice.
Bill has 20 yrs. of experience with our Dodge transmissions
I know you will be happy.
Bob
Heres a link
http://www.dieseltrans.com/DTTech/controller.htm
JCotte,
What is a mystery switch and its function? Good question.
The pcm controlls the tc lockup clutch solenoid . By gounding the solenoid it basically locks up the tc clutch inside the torque converter.
It does so when it receives the signal from the throttle position sensor, and vehicle speed.
By installing a manual switch, you are simply bypassing the pcm by supplying your own signal to the lockup solenoid.
A torque loc basically does the same thing, with the exception of it automatically dis-engages the lockup at a preset speed usually 30 mph .
These devices sound pretty hamless dont they?
Its not until you actually understand what is happening inside the torque converter and transmission by using these devices do you realize what the concequences are, and by then its usually too late.
I used to get pretty worked up every time the subject of the the torque loc came up, you guys that are new can do a search under it, some of the info is actually pretty informative.
If you owned a 5 speed or 6 speed transmission, would you put it in 5th or 6th gear depending on your transmission and leave it there, no matter what, light throttle , heavy throttle,full throttle, uphill, downhill, would you do that to your standard transmission?
If the answer is yes then i would suggest go ahead and get a torque loc, as it forces the same results in the automatic.
In other words, you pucker up and be prepared to kiss your tc goodbye.
The results will be the same whether you have a factory tc or and aftermarket one. The aftermarket tc may hang in a little bit longer but the results will be the same.
By engaging a torque loc or a mystery switch this activates the loc up circuit in the vb, it basically locks the transmission into that one gear. It does not allow any passing gear to happen.
You can verify what i am talking about by using a pressure gauge on the governor port. I can tell you guys that want to verify this how to do it if you want to , you can call me, make sure you have a 0-100 psi pressure gauge with about an 8-10ft hose.
We realized however there was a need to have an exhaust brake system for the automatics for safety reasons, we had to figure out a system designed to protect the transmission and the tc.
Let me warn you guys of this, dont let anybody kid you guys, any system will cause some wear and tear on the transmission.
When we designed the smart controller for the automatics we looked at serveral reasons why the transmissions were failing when using an exhaust brake,
One feature we added to the controller was a tps signal, by adjusting the signal you can unlock the tc at a pre-set throttle position simply put passing gear.
The other feature we put into it was the od circuit.
We wanted our controller to automatically dis-engage od if you dropped below the pre-set speed to keep the rpms high.
We wanted the transmission to be able to automatically gear down as selecting the right gear ratio comming down a hill is just as important when driving a standard.
Ex, if you were slowing down from 60 mph and your vehicle speed hit 50 od would automatically be dis-engaged.
We designed 2 versions of this , one was for city use and the other for highway use.
The city version basically locks out od all the time below a certain speed.
We have also added a 2nd gear loc up feature that disables lockup at a preset speed.
The oem factory vb does not allow 2nd gear lockup in its orignial state.
The reason why we went to such great lengths is because we know the importance of keeping the rpms high, we needed to protect the lock up clutch.
Most any exhaust brake you will find is good quality,
On a standard you can pretty much put any exhaust brake on it and will get good results.
On an automatic i chose the PacBrake because of the excellent retarding hp at the higher rpms and at the lower rpms the Pacbrake does the least amount of tc clutch damage compared to the other brakes on the market.
Your tc clutch at is weakest below 1600 rpms simply becuase of centrifigual force.
