exhaust
Truck climate control
2 wd 06 rear axle nut adjustment
tring to find replacement exhaust for 05 std cab long bed that has no converter in it. will a exhaust for an o3 fit it
All the exhaust makers have a turbo back system with no CAT in them. Muffler optional also. If you can afford it buy the complete syste. If not, cut the CAT out and replace it with muffler.
want to replace the complete exhaust. every time i order one it comes with the exhaust that keeps the converter i want to put a Banks 4 in on it so will a banks 4in from o3 fit it
You need to order a 4" TBE for an 03-04, but specify that you have a 04. 5-07 4" turbo elbow.
When I was exhaust shopping for my 05 last year, I was overwhelmed with the information and options out there for several 4 or 5 inch turbo back exhaust systems. The MBRP kit I purchased fit any wheel base (there was an extension I didn't use having a short bed).
I'm happy with mine. Seems you should be able to stumble across something.
Make sure you get an exhaust that will not hinder with the performance of your vehicle. The exhaust should bring out the best in your vehicle. Get this information from your mechanic and see the horsepower so that you can get a matching exhaust.
Happy as a PIG IN I TRIED TO BY-PASS THE CUSSING FILTER with my Stans Headers exhaust has the cat cut out but has flanges just in-case they want to see it with it in.
BOB 4x4 nice DISCLAMER about the OFF ROAD ONLY!!! :-laf never know where those EPA and AQMD people will be looking for tips on violators of the code's. :-laf:-laf
BIG
Duc,
Geno's Garage has a MBRP exhaust system, # MBRP-S6104P , turbo back system. $319. 00 I bought one for my 04, Wifes 05, and our 01. Best fitting and sounding exhaust. No Drone running down the highway. Took longer to remove the stock one than it did to install the new system.
