rbattelle
For those like me who think the transfer case shift lever would be more convenient if it were taller, here's one way to extend it. You need the following materials:
1. 1/2" aluminum rod. Specific alloy is not important: just get general purpose (6061). These may be obtained from www.smallparts.com I bought a 1 ft. piece.
2. A 8. 5mm twist drill and M10x1. 5 tap (8. 5mm is the tap drill size for M10x1. 5).
3. A 25 to 40 millimeter M10x1. 5 hex-head bolt.
To do the job:
1. Cut the aluminum rod down to 7 inches in length. You can make it shorter, but anything longer may not allow you to shift into 4L, as the top of the shifter will strike the dash. Also, anything taller and you're risking interference with the transmission stick (for us manual guys).
2. Drill about 2 inches into each end of the rod using the 8. 5mm bit. Tap those holes for M10x1. 5.
3. Remove the transfer case shift knob by gently prying out the "4L-N-2H-4H" plastic piece, then removing the hex nut (use a 15mm socket). Unscrew the shift knob from the shift arm.
4. Take that hex nut you just removed, and screw it all the way to the bottom of the threads on the shift lever. It will be used as a jam nut.
5. Thread your aluminum rod onto the shift lever until it contacts the nut. Then unscrew the hex nut from step 4 to jam it up against the aluminum rod.
6. Screw the M10x1. 5 bolt you bought into the shift knob, then screw that assembly into the end of your aluminum rod. Finally, replace the "4L-N-2H-4H" piece.
In the pic, I've pulled the boot down below the jam nut. Normally I keep it pulled up over the nut. I think it looks better that way, and it keeps "crud" from accumulating down in the boot like it does in the factory position.
To do the job:
