1600 rpm stumble
I've been having a similar problem recently that is intermitent, but getting more frequent. I would describe it as a stumble, almost as if my foot slipped off the accelerator. I mostly notice it during light acceleration with the Comp on a low (usually 1) sublevel, but have felt it at higher rpm, 2000-2200. I don't know if this is related, but I occassionally get P0237 codes, which can set the CEL. My OBDII scanner is beginning to pay for itself with code clears.
I've tried turning the Comp off, particularly when the engine is cold, but still get the stumble, just not as pronounced.
Today, I disconnected the Comp harness: Map, Data Link, and power. I made a 250 mile trip, with several stops. At no time did I experience any stumble. I miss the responsiveness and extra power, but the stumble and codes bother me a lot. I'll drive it this way for a week to see if the difference is consistent.
I would give up the Comp and go for a Catcher, but I don't think either of the current Catcher programs are ideal for an HO motor with a 6-speed manual. I think a Catcher program for the HO-6spd needs more timing than a Special and less timing than a Regular, and a less aggressive fueling rate to avoid the all-or-nothing throttle response and "1/2 pedal" syndrome.
So Marco or Bob, if you think there's a big enough market here to warrent a third program for the HO-6spd contingent, I'll be more than happy to provide feedback
Thanks,
Neil
