Factory fuel tank
Complicated RA4 Uconnect amp draw issue
How Much DEF Are You Using In Miles?
Hi all just got back on a month vacation with the dually and 5er. Only complaint was the whimpy fuel tank. I found a guy that has a factory 50 gal out of a 2023 dually. Will this fit my 2018 dually?
It will not, the mounts for the OEM 50 are different. Why does a guy have a 2023 tank for sale?
I put a Titan 55 gallon tank in my 2018 and it was a worthy investment.
I didn't ask. He did have the mounting brackets but it sounds like connection points are different?
That’s my understanding.
None of the aftermarket tanks I’ve looked at will work if you have the OEM 50 gallon tank.
So if I am reading this right.. there is no point in looking for a 50G OEM take out for my 2020 as I had been? I currently use a 60G aux tank for towing, but was considering the swap, but if it will not mount then I'll stop looking
I checked the S&B website and the same 5050 gal tank is used on 2007-2023 . Your thoughts?
I don’t see any 50 gallon tank on their website. The only tank they have that’s close to what you posted is a 52 gallon tank for 05-23 short bed trucks.
I was under the impression you had a CCLB DRW, not a MCSB DRW. What truck do you have?
Correct, if you want a larger tank you’ll need to go aftermarket.
I have a long bed dually crewcab. Yes the S&B is 52 gallon. The seller sent me center to center for the mounting bracket. I'll crawl under and check it this morning.
