Not a lot came up on my search, so I'll ask it here..
I've got a fan clutch replacement project this weekend, and am looking to make it as easy as possible...
So far, I've gathered I need a 36mm open end wrench(for fan hub nut),
possibly a large C-clamp(to hold pulley from rotating... I rented the tool set from FLAPs and it didn't fit anything for this job
and 10 and 13mm box end wrenches(for fan blade to clutch bolts and to remove a couple pulley bolt for room for the wrench...)
From your experience, Anything else I should need?
Also, does anyone know where the wiring goes on the frame(that the fan clutch plugs into)? My wires were cut and plugs removed at some point by a PO(maybe for manual control with a tuner?? *shrug*)..
I'd like to replace that chunk of harness, if it's plugged in somewhere at the other end..
Thank you!
Thank you!
