Engine/Transmission (1998.5 - 2002) Fan shroud modification??
In several issues back, there was someone who did a fan shroud modification by making some incisions to the fan shroud. This enabled removal of the fan and fan clutch without removing the entire fan shroud. Once the job is done, you simply get a small piece of metal or plastic with a couple screws to stitch it back together. I cannot for the life of me find the post, or the issue.
I am just having difficulty removing the reservoirs for the washer fluid and coolant. I already have a leaking washer fluid reservoir and don't want to make things worse. :eek:
Try this: https://www.turbodieselregister.com...ission-discussions/197499-fan-shroud-mod.html
Bill
