FASS fuel pumps
Oilguard Oil Return Cap
Which Injectors??
Read a post recently about upgrading my FASS system to something quieter. Followed instructions and sent pump to FASS with my $15 check. Pump came back as packed, with my note and check??? No note from FASS, no phone call, no explanation of what was done or not done, nothing I assume since they returned my check.
When I bought the pump from a San Antonio dealer they sent the wrong filter, about 1. 5 qts, parts that had no apparent use, 3- 3/16" spacers, 2-3/4" spacers instead of 4-3/8" spacers for mounting the pump. The dealer (when he finally got to work around 9:30 AM) told me the pump was a high flow pump mounted on the wrong base - SURE. Try to call the factory - good luck.
I believe FASS makes a good product but service and customer relations suck.
Diesel-Dan,
You seem to be the man to ask about the FASS 150, I have a 4 year old Fass 150 I bought from PDR and I have been very happy with it. But now I am running 100% biodiesel and I know I need to replace my fuel line with Viton lines.
1st my pump has never been updated,
2nd Do you all sell a line upgrade kit that is biodiesel compatible?
3rd what other things do I need to do/upgrade to my FASS 150 to ensure that I will not have any biodiesel related problems?
Thanks
Kyle Hoover
Abbeville SC
https://www.turbodieselregister.com/forums/1513803-post1.html
That will give you the update cost... .
Call Eric... he has done tons of update for me. He knows the ropes on that... and for the extra stuff... ill have to sit down and price them... should be too much more. BUT im tight on time at the moment, so i will post more later... . thanks!
Dan.
My FASS 150 falls within the S/N range for the update. I orginally purchased my FASS from PDR. Would I call them and order the appropriate update from them? Or can I order from any FASS Dealer? Also Do I send the core back to them or you? Also I need my truck daily, do I send the Core in when the new pump gets here or do I have to send the core to get the new motor?
Sorry for the questions.
Thanks
J-
Dan,
I've got over 90k on my original FASS 150/95, when should i think about changing the brushes??
Rick
