FASS Pump Without Kit?
NV5600 Transmission Heater Pad for winter use
95 Series Fleetguard Filter Cross Numbers
Greetings! My truck has a OEM LP mounted on the frame rail using a Vulcan relocation kit. I have 3/8ths ID fuel hose (with hose clamps) from the tank to the VP44. I am installing a Vulcan 3/8ths Draw Straw in the fuel tank this weekend. I would like to replace my Carter LP with a Fass 95 unit without the fuel filter/separator; however I would like to continue to use my existing fuel hose and fittings if possible. I realize that I would need a FASS mounting bracket and probably a wiring harness and maybe a regulator?. I have done some searching at various websites and I can't seem to find one that offers a stand alone Fass unit with the mounting bracket/wiring harness. Anyone have suggestions on what else I may need and where to buy it. Thanks.
fass pump only
talk to eric at www.vulcanperformace.com
he sells them. my pump came with a bracket and fittings out and in and I order new 3/8 id hose rated for bio. the pump should have the pump connection to plug into the stock pump wire plug.
or talk to diesel dan he is on her alot. since he is incharge of warranties and troubleshooting for his pumps.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " 4"EXHAUST D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf... THANKS RIP Source Automotive Performance Diesel - Home
