Feul Filter Change
HO Lift Pump Flow Rate
Clueless regional rep
I changed my filter 2nite, I thought the 3G had self priming pumps/filter. It took me about 10min to get the truck started after the change. I used the fuel dump valve. TIA Scott :confused:
Ya gotta let the lift pump run to refill the canister. Just bump the starter and listen for it. Do this once or twice, or three or four, whatever. The pump should run for 20sec or so.
