Fleece Cheetah turbo
Nv5600 reverse
Brake light/ABS light on
I just installed this turbo recently. My EGT’s have increased a lot. The turbo is lagging and boost just doesn’t jump up like I thought it would. I have Exergy 50hp injectors, sb air filter, Fuelab Velocity 100 lift pump and use the Smarty S06 POD tuner.
I’ve already tested for boost leaks and none.
Any ideas?
Assuming checked the intake as well for any restrictions and for exhaust leaks? I know many people running that Turbo with great results so unless it was bad from the factory I doubt its the Turbo itself.
