Flex-A-Lite 5200cfm Fan
Care and feeding of NV 4500???
what's the fix for the cold weather power steering howl?
I am ordering the Horton setup soon. I have had 2 instances on gas cars that had Flex-a-lite electric fans that failed. In one instance the radiator petcok blew off. The other case he shutdown before it overheated. They make nice stuff, but i dont trust an electric fan on a $4,000 engine. Just my 2c
I've been fanless most of the winter. With the Lund winterfront on, I'm OK till about 65 degrees @ highway speeds.
I just put the fan back on today because I want to go out in the TT soon.
Wacky weather. 20 out the night before last, Sunday theyre calling for 85!! ?? #ad
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 265 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
This debate will probably out live our trucks. If one reads the entire thread above, it is hard not to reach the conclusion that 'it depends on the application'.....
I have not removed my fan, but will next winter. I block all but about 6-8" circle in the center of my radiator with a hunk of thin plywood. That comes out when the temp hits about 32F if I am on the highway, as my gauge will start to show far too much heat.
If my OEM fan clutch ever goes, I will likely try the electric solution. (only because I don't really push the truck that hard except when I come back from visiting the diesel gang in California) #ad
the debate continues...
MUD SEASON + AN OVERPOWERED RAM = DIRT DIRT DIRT #ad
