Flex-a-lite electric fan
what are the best brakes to use on a 3500?
Exhaust brakes
I contacted them on the universal twin electric set up. They told me it would work as long as I did not do extreme towing.
E-Mail them off there website, they will let you know for what your driving conditions are.
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with 305/70R16, Smittybuilt stainless nurf bars, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!!
I swithed one of my old Chevy Monza Gassers over to an electric fan several years ago. One morning I went out, started it up, went back inside to let it warm up.
when I came back outside I found the water temp gauge had gone around about 4 times the engine was so hot. the electro thermostat had failed and the fan never came on.
Needless to say, the engine only made it about 10 miles and it through a rod through the oil pan. (the best part was what happened to the guy's windshild who was tailgating me, something he will never forget)
I saved a couple dollars on that fan, but your Cummins would cost over 4K to replace!
Luckly I had a fresh 231cid Turbo V-6, 4-brl, (first turbo motor that lead to the Grand national) ready to drop in. Thinking back, I was enjoying smoking the Furds back then too!, but then it was the 5. 0 Rust tangs I was smoking.
I had the same thing happen on a Chevy gasser I had an electric fan on. Although it didn't get too hot, and I got in th truck before the temp went over 260.
This is a very serious concern I have about putting an eletric fan on the beast.
I guess you get what you pay for. I have not heard of anybody having problems with the Horton. Except in the pocket book!!!!
2001 RAM 3500 dually Quad Cab SLT, 4. 10 limited slip, HO 245 hp, 6-speed, dark garnet pearl coat, interior agate, All options except heated leather, added DeeZee brite diamond tool box, Linex spray-in bed liner, Lund hood deflector 3 piece smoke color, DeeZee brite diamond cab/bed running boards and TurboSaver (from Gino's) also Reese 5th wheel 15k hitch. No plans to bomb. This is my retirment vehicle currently pulling 21' 5er want to buy 30 to 35 for retirment.
Are you wanting to ADD an electric fan?, or replace the stock engine driven fan entirely with an electric?. If you are wanting to add a fan, i dont know where you could fit one in, i thought of doing it myself to help in the real hot summer months but everything is so tight, i dont think you could fit a fan big enough to be worthwhile. And as far as replacing the Engine driven fan, that would not be worth it. As mentioned above, thats a VERY expensive engine to risk blowing because of a fan or T-Stat failure. If anything, i would go with the Horton setup. Really expensive, but will definatley help with engine cooling and A/C.
