Flex-A-Lite Electric fans
Need an aluminum OEM wheel for my 2001 2500.
2003 QC Laramie Dually
I had this fan setup on the truck for about 5000 miles. They work great in the summer with the a/c on and loaded. I posted the info below off of Flex-A-Lites web page. Flex-a-lite® Quick Start Variable Temperature Controller with thread-in temperature sensor included. Like new with all mounting hardware. I could not get my pictures to load. E-mail for questions or pictures. -- email address removed -- . Thanks, Sam. $300
Quick Overview
This is a direct-fit, bolt-on Flex-a-lite® dual electric-fan system for ’94-’02 Dodge Ram trucks with diesel engines. Recover up to 27 horsepower and boost your fuel economy by up to 6 percent by replacing your stock clutch fan assembly with this dual electric fan system. It features two 15-inch S-Blade electric fans and a Flex-a-lite Variable Speed Controller that varies the fan speed from 60-100 percent, depending on radiator temperature. These powerful fans move up to 5,500 cfm of airflow!
Direct-fit, bolt-on design
Approximately 4 hour installation
Up to 5,500 cfm of airflow
Quicker engine warm up
Variable Speed Controller with A/C relay
Is this still avialable?
Please reply to -- email address removed --
Thank You
Brian
Thank You
Brian
