Thats what I like to hear, a product that is somewhat idiot proof
Emerald5. 9 said:Have you guys that have changed out to the fluid damper, noticed any power improvments,MPG's etc...
HEMI®Dart said:$329 Group Purchase.
jwilliams3 said:After all of the Holiday hussle and bussle and the new baby,
and some unseasonal warm weather;
I have finally got around to installing the Horschel "Fluidampr" on my 2004. 5 6 speed.
About a month or so back Peter from SOUTH BEND CLUTCH started a thread on TDR and the other website about this product.
We were both interested to see what kind of effect this product would have on a truck with excessive gear rattle.
After some conversation he was nice enough to buy me one of the fluid dampers!! THANKS PETER!!!
For those that do not drive SBC Dual Disc clutches:
Gear rattle is increased somewhat and can be heard and sometimes felt.
This is apparent at idle and while lugging gears this condition also becomes apparent.
As it has been said before there are no springs on the disks to dampen driveline shock when using dual disc clutches. There is simply not enough room for them.
Installation:
I removed the 4 13mm nuts that retain the fan shroud to the engine mounts.
That allowed me to reach the damper from under the truck.
I then untorqued the 4 15mm bolts from the front of the engine that retains the damper.
I was careful not to damage the famous tone ring that resides behind the OEM damper.
Installation was pretty simple, just slid the new piece up and onto the nose of the crankshaft.
Horschel has already drilled for the timing pin in their damper so it slides right on. This unit is also SFI certified for those needing to have a SFI'd damper.
Another nice thing is that the damper has a TDC mark just like the OEM unit.
Horschel unit weighs in around 23lbs.
The only issues I ran into were the belt routing after not paying attention to how it was sitting when I removed the original damper.
I referred to a tech manual and then had it down pretty quickly.
You will need a 1/2" torque wrench for installation and a long 16" or so 1/2" ratchet.
Results:
Well, I got it all back together again and started it up.
Right away I noticed alot of the gear noise at idle is gone, the truck sounds 'more stock' again.
I took it for a drive and there is definitely a difference;
it seems alot of the transmission noise is gone and vibration has drastically reduced.
I have only driven about 15 miles with the unit installed but so far it seems to have made a nice difference.
We'll see as the newness wears off and I will make some more reports.
So far its great though!!
jwilliams3 said:Yes you will have to remove the damper or loosen it up to change belts.
Thats the way I do it at least... there might be a smarter way I dont know about yet.
