FP Guage reading
Water Methanol Injection
Comp Box - 2nd Gens - Where'd you mount?
When I first installed my Westach FP guage I had 14 at idle and would not fall below 10 when cruising. I changed FF after FP guage install and pressure dropped by 2lbs. Now at idle I see 12 but can drag it down to 6 while pulling trailer. Is there just air in line or am I seeing lift pump slowly dieing? No codes and truck seems to run fine. Truck is stock other than what you see below.
try this:
loosen the F/F lid and prime the system as soon as you see fuel coming out the top tighten the top down
this will remove any air in the F/F housing
check for air in the F/gage line too
i have had these problems before and it seem to help
Scott
