more brake problems, replaced rotors, pads, bearings, drums, shoes, wheel cylinders, all rear springs and flexible rear brake hose, now finally got the rear brakes to work properly and right on que the front brakes starting dragging, when rolling up to a stop the truck will stop on its own, thought it was the rears and brought it in jacked up the rear and they were free, jacked up the front and they would not move after pulling the wheel off checked the calibers and pins all OK, put a c-clamp on the inner pad and could not force fluid back to the master cylinder to release the brakes, cracked the line at the master cylinder and they turned loose. it acts as if the brakes are slightly on (pre-loaded)????? Checked the brake pedal and rod for adjustment and doesnt seem to be a problem there, loosened the master cylinder a little and it allowed the pressure to release, OK now for the question why would the brakes get pre-loaded, is there an adjustment for the rod from the master cylinder to the brake pedal? Cant see how it could have changed but its as if the brakes are slightly on and wont release, could it be a faulty master cylinder? any help would be appreciated... .
