Front driveshaft bolt size?
2003 2500 Front Driver's Axle shaft
2005 turbo diesel power steering pump
Hello,
I'm replacing my front pinion seal and fighting with the damn front yoke torx bolts. If I EVER get them out, they're not going back in. Would anyone know what size hex head bolts would replace them?
Most hardware stores or automotive supplier will have a flanged cap screw that will work. Just take one along for sizing.
Hello,
Having just dealt w/ this issue myself a 5" or longer T40 torx bit will make this much easier, so much so you may just forget about the new bolts. I had a hard time finding a T40 that long so I cobbled a 1/4" drive to hold a T40 in a socket w/ an extension, then adapter to allow a 1/2" drive using an impact on the lowest setting u can. They should just come out and back in. Took better than an hour the first time I removed it, using this method few min.
Can't take all the credit Bob4x4 shared the important info so I knew where to start!
Thanks Bob
I too just went through this. I actually went to Dodge and bought, new bolts, Yeah; more money that brains. But in retrospect, if you're carefull you don't need to ruin the originals. Turns out they are installed with loctite. That's why they're such a "B" to remove. But a moment or two with a propane torch will soften the loctite and they come along easily. I've dropped my fron shaft several times and just a little heat is all it takes to get things moviong.
Good Luck.
I found some hex heads and put them in, now all I need are two wrenches to remove the driveshaft. I did manage to get them out with a emergency tool purchase and lots of heat!!!
