In a previous posting I asked for some leveling kit advice but have now abandoned that plan for a while. The other day I had my wife start the truck while I climbed underneath. When she moved the wheel back and forth I was shocked! The track bar was moving up and down in the Luke's Link, three of the four tie rods had significant slop, and the output shaft on the steering gear had a little slop. There was no point in leveling the front until that stuff was fixed. One long wheelbase hundred dollar bill later I had a new DSS, 4 new Bilsteins 5100's (shocks were shot too), new Luke's Link track bar bushings, and all the Moog steering linkage parts to upgrade to the 98-99 HD T-steering. The shocks and DSS are in and a noticeable amount of slop in the steering is gone. Next up is the steering linkage and track bar maintenance.
Questions:
1. Should the threads of the tie rods be greased or anti-seized before being threaded into the adjsuting sleeves?
2. If I take the track bar completely off to shim up the Luke's Link and install the new bushings should I be concerned about getting it all lined back up right or should it go back together just like it came apart.
3. How do I know how many shims to put in the Luke's Link?
4. While I was underneath the truck I noticed the passenger side front axle universal joint grease seal has a chunk missing out of it exposing the needle bearings. The universal joint does not appear to be able to be separated from the axle shaft itself. Is this going to be expensive to fix? I think I know the answer but if you know different, I'll be happier than I am now.
Info Note:
Pay close attention to the instructions for the DSS. When it says support the sway bar while you remove the bolts, it MEANS hold the sway bar while you remove the bolts. Mine stuck to the frame just long enough for me to set the impact down and meet it with the corner of my left eyebrow as gravity took its toll on the very heavy sway bar. One black eye later:{... . DSS works good.
Questions:
Info Note:
