dougdodgeman
I have an '06 3500 4x4 with 124,000 mi. that developed an oil leak from the timing gear case area about 10,000 mi. ago. I had the truck in the dealership for it's third tipm[another story] in preparation for a 1000 mi. trip and asked what they would charge to change the crank seal while they had it. They said it called for 3 hrs. , so I said to do it while it was there. I thought this was the leak, but evidently it was not as they called to say that it didn't fix the leak and that they couldn't tell w/o tearing into it where the leak was coming from. The only other thing I can think of would be the gasket between the block and gear case. The oil cooler is dry, but the a/c compressor is soaked as is the corner of the gear case and it doesn't look all that wet above that lower area. Does anyone have any other experience or suggestions? Thanks!
