JMcCoy, thank you for your response. I should have given more information, so here are the details. First, I identified the wrong tire - the right front tire is the one in question. This winter I did major front suspension and steering repair work with the intention of giving the truck a reliable second life for my retirement. The truck now has 225,000 miles on the odometer (215,000 when I did the work). I replaced all upper and lower ball joints, track rod, worn steering parts, steering gearbox, and steering shaft. I added the steering box brace. I did other work as well, but not steering or suspension related.
I had set the caster to a much more positive angle (how much is unknown) and had set the toe to as close to 0 as I could using a tape. It was probably toed in slightly. After doing this work, I have driven the truck empty and towing 4000 to 6000 pound trailers for a few thousand miles. Towing probably accounts for fifty per cent of the miles. The truck handles and steers well under all conditions. I had the wheel alignment checked with the following results:
Caster - 4 1/2 degrees (left and right)
Camber - +1/4 (left) 0 (right)
Toe - 3/32" in
The alignment shop made no changes. My tire wear observations have not been well documented, so I may be overly concerned. Anyway, for my own peace of mind I want to get a second recording and opinion from a recommended alignment shop for the kind of trucks we drive.
Thanks again for everyone's response.
