2nd Gen Non-Engine/Transmission front wheel bearings
2nd Gen Non-Engine/Transmission Westach Temp gauge bad?
Try search. Someone posted recently the company that makes them for Mopar. When bought directly they were a significant savings over the dealer. Their also emsoffroad.com or dynatrac.com
Thanks for the reply. One more question though. How do I know if the bearing is shot? I heard that it will roar, but his truck has more of a squeak and a rattle. Is there any way to be sure that the bearing is bad?
Jack up it up, spin the wheel, if it sounds like marbles are in the bearing; it's bad. It should be smooth and quiet.
$180 - $190 thru Napa.
Good luck.
just had mine go bad on my driver side. 990 bucks later i had new upper and lower ball joints on that side, plus a lug replaced and it aligned. new wheel bearings can be gotten from napa and autozone has them. the shop told me that it was a bear to get out, the wheel bearings had rusted in, it took the longest to get the WB out then to do the rest of the job.
