rbattelle
Well, I decided to test with vegetable oil because I was anxious to get some testing in and the weather here has recently turned to complete crapola. Veg. oil lets me test in the garage with no fears of fumes/fires.
Anyway, I ran the first phase of tests last night. These were done without the filter in the loop; just the pump and regulator. I found the pump self-primes very easily (as expected).
The pump current varies linearly with changes in RPM, with maximum RPM corresponding to maximum current draw. I plugged the regulator output line and ran the pump at maximum pressure and the maximum current draw I could achieve was ~4. 6 amp. Very mild.
So I ran an endurance test for 1 full hour, collecting temperature data at the MOSFET chip the whole time (sampling at 1 minute intervals). Pump at maximum RPM, current draw ~4. 5 amp average. Maximum temperature achieved was 86. 3*F. Horizontal asymptote is probably around 100*F, but that's just a guess (not enough data).
The pump was pretty noisy, although that's probably because it's bolted to a piece of plywood. When I fabricate the mounting bracket I'll need a lot of rubber isolation. Lmills, who was running the same pump, said he was able to hear it running with the truck at idle.
Tonight I'll plumb the filter into the system and take some pressure data. But it's pretty clear that the PWM will work quite well in this application.
-Ryan
-Ryan
